Thread: New Duct Fitting template: is there one?
    2006-08
    58
    Default New Duct Fitting template: is there one?
    I want to create a new duct fitting, but when i start a new family i find that there is no 'duct fitting' template as such. Anyway, I used the 'Mechanical Equipment' template but this means that when I load the family into a project, it becomes listed under the 'Mechanical Equipment' items and not under 'Duct Fittings'.
    Is there a duct fitting template? Or is there quick a way to change the category of a family so that it will list under a different category i.e. the duct fitting items?
    Thanks for any help,
    Bren.
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: New Duct Fitting template: is there one?
    While in the family editor you can go to Settings/Family Categories and Parameters and you should be able to change it to the Duct Fitting category. I don't have a copy of MEP so I can't tell you if there's a template you're not seeing.
    2006-08
    58
    Yes!! Thankyou Dimitri,
    That was exactly what i needed. I've changed the family category now and reloaded it into my project. It now comes under duct fittings.
    Cheers,
    Bren.
  1. 2014: Duct Fitting Disappears
    By slovenc0417 in forum Revit MEP - Families
    Last Post: 2015-04-24, 07:38 PM
  2. 2015: Duct fitting grey
    By amigost in forum Revit MEP - General
    Last Post: 2015-02-26, 04:48 PM
  3. 2014: Need a duct fitting that would split a rectangular duct in two ways
    By BalajiBBI in forum Revit MEP - Families
    Last Post: 2014-12-17, 01:56 PM
  4. Duct Fitting Lineweight
    By phil.pleiss in forum Revit MEP - General
    Last Post: 2010-09-13, 08:08 PM
  5. Custom Duct Fitting
    By ntopliffe in forum Revit MEP - General
    Last Post: 2009-10-15, 12:03 AM
