wahyudin
one important rule when creating/insert a dynamic size block ( the size is preset to increase/decrease based on the dimension scale) i.e in creating/inserting annotation blocks, or your custom leader, is to set both the insert definition source units and insert definition target into the equivalen value i.e mm w/ mm or inch w/ inch, and set the current units to have the same setting too. maybe you forget to set them, so the block didn't works correctly
check these variables when you going to create and insert block
insunitsdefsource (value)
insunitsdeftarget (value)
or you may set them on the options dialog
don't forget to set the current units to have the same value too
hope this works
thx
