Thread: geological point data (xyz) from AutoCad to excel
    2007-10
    Question geological point data (xyz) from AutoCad to excel
    Excel will import dxf files with geology xyz data but... not comprehensively. My files are large (+3000 data points) so i can't manually pick out the points from the scrambled excel output.
    I tried getexcel.lisp in Autocad 2007 and it would load but wouldn't run.
    is there a way to gey the xyz point data into a comprehensive excel spreadsheet using only autocad 2007?
    i need the data in spreadsheet format to input to a Surfer grid.
    thanks.
    2006-01
    202
    Default Re: geological point data (xyz) from AutoCad to excel
    Can you get hold of or use any Survey processing software? Most will do this for you.
    We use one called n4ce which exports the points as a txt file which can then be imported into an excel file if needed.
    I would imagine anything similar would do this task for you.
  1. transfer point from AutoCAD to excel
    By e.mounir in forum AutoCAD General
    Last Post: 2017-05-21, 12:09 PM
  2. Macro to copy data from Autocad to Excel
    By jayabalan1003695339 in forum VBA/COM Interop
    Last Post: 2015-05-29, 10:33 PM
  3. Bring data to Excel from AutoCAD
    By cparvez in forum Dot Net API
    Last Post: 2014-05-27, 08:46 PM
  4. Point Coordinate from Autocad to Excel
    By fhairul495794 in forum AutoCAD General
    Last Post: 2011-07-31, 02:45 AM
  5. How do I get excel to paste into AutoCad at a specified point?
    By stephen.forbes.203356 in forum CAD Management - General
    Last Post: 2008-12-20, 05:51 PM
