Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: AutoLISP routine to calculate the total weight of steel
    2004-07
    Detroit Michigan
    2,508
    Default AutoLISP routine to calculate the total weight of steel
    Im not real good with lisp so I am asking to see if anyone can create a really useful, but Im guessing quick to make, lisp routine......what I need is a lisp that takes the
    area of a 2d object, asks for a material thickness to be input, and completes this calculation (area) x (thickness/25.4) x (.2833) whereas thickness in in millimeters and .2833 is the density of steel. This would calculate an weight estimation.
    Any help would be appreciated
    2003-11
    YUL
    75
    Default Re: AutoLISP routine to calculate the total weight of steel
    See if this helps.
    Paul.
    2004-07
    Detroit Michigan
    2,508
    That is a neat lisp routine but I am looking for a quick lisp routine
    for a flat blank.....ie blank area X thickness X density
    My drawings are basically 2d, steel blanks, that sometimes have
    cutouts.
    2003-11
    YUL
    75
    ...then it must be this one......
    2004-07
    Detroit Michigan
    2,508
    Not quite,, the area should be from the area command, so I can pick an object on the screen. Density is also a constant, all we use is steel .2833
    2002-02
    St. Louis, MO
    4,695
    You might consider going 3D. Extrude a region to the thicknes needed and you'll have your mass. You can then use the MASSPROP command to list out all sorts of structural properties and even write the data to a text file. All of this is automatic in 3D. No lisp needed.
    2004-07
    Detroit Michigan
    2,508
    That would take too long........but ok. Im working with flat blanks from a blanking line and creating process drawings.
    2000-01
    Seattle WA USA
    5,859
    Does the area need to be adjusted to inches also? Or are the objects drawing with units defined as inches?
    2004-07
    Detroit Michigan
    2,508
    Thumbs up Re: AutoLISP routine to calculate the total weight of steel
    Drawing units are in inches...so its ok to use .2833 in the calculation.
    2000-01
    Seattle WA USA
    5,859
    Lightbulb Re: AutoLISP routine to calculate the total weight of steel
    Attached is a program that does what I think you want.
  1. calculate the total length of a group of polylines
    By eebryant in forum AutoCAD Map 3D - General
    Last Post: 2008-10-20, 06:36 PM
  2. Calculate weight
    By Ed Jobe in forum ACA General
    Last Post: 2008-04-14, 02:16 PM
  3. Calculate Steel Weight
    By nick.beaven in forum Revit Structure - Wish List
    Last Post: 2007-12-17, 02:56 PM
  4. total building weight
    By Steve Jager in forum Revit Structure - General
    Last Post: 2006-11-01, 05:46 AM
  5. Total building weight
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2006-10-31, 03:55 PM
