Results 1 to 6 of 6
Thread: Revit Architecture Rotation Tool
    2007-10
    3
    Default Revit Architecture Rotation Tool
    For some strange reason the 'center of rotation' icon disappears from my object when i select the rotation comand. the really odd thing is that it appears on other objects in other views. It also appears on my co-workers computers when selecting the same original object.
    Does anyone have a solution for this amazing revit quirk?
    2003-04
    Irvine, CA
    6,770
    Default Re: Revit Architecture Rotation Tool
    Any chance this is happening in a view with a cropped region? If the center of rotation is not directly over the element (like for an arc for example) then it might be outside of the displayed portion of a view.
    2007-10
    3
    Its definetly a cropped region. The element is a detail component though, small and within the boundry of the 'cropped region'
    2006-04
    Baltimore, MD
    379
    Check the detail component family. The center of rotation will default to where the two origin defining reference planes intersect.
    2007-10
    3
    Its o.k. in the family. Its a really wierd quirk. I cannot explain.
    2006-04
    Baltimore, MD
    379
    Quote Originally Posted by chanus View Post
    Just to clarify - do you mean the center of rotation is ok in the family, or that the intersection of the reference planes are at the center (or close to) of the detail component linework? I'm just asking, because you won't notice the ref plane part until you load it into a project.
  1. Revit Architecture - How do i import files from Autocad to Revit Architecture 2010
    By widyaiswarapratiwi370240 in forum Revit Architecture - General
    Last Post: 2012-01-09, 03:43 AM
  2. Add a loft tool to Revit Architecture
    By Revit Wishes in forum Revit Platform - Wish List
    Last Post: 2011-08-23, 08:54 PM
