Thread: Need single-door equivalent of Revit's "Store Front Double Door"
    2007-07
    9
    Default Need single-door equivalent of Revit's "Store Front Double Door"
    The out of the box Revit library provides a curtain wall "storefront" double door with the above name (in family "Curtain Wall-Store Front-Dbl"), but no single-door equivalent, which I need. The only single-door glass curtain wall door I can find is "Curtain Wall Sgl Glass" in a family of the same name, but it has no frame around the glass.
    I'm not up to speed (yet) on parametric family creation, else I'd simply morph the "framed" -Dbl into -Sgl.
    Does anybody know where the equivalent single door is, or any set of matching single- and double-width metal-framed glass curtain wall doors that can be "stretched" to various widths and heights like the above?
    Thanks.
    2003-08
    Vancouver, BC Canada
    3,392
    Default Re: Need single-door equivalent of Revit's "Store Front Double Door"
    This work for you?
    You can modfiy it to suit your needs. (NB It's created from a metric template)
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2007-07
    9
    Yes, that worked just fine! It didn't seem to matter that it was metric.
    Strangely, the name displays "%20" (programmer-speak: hex code for ascii 'space' character) in place of spaces and was trailed by a "[1]". I've seen this frequently before, but have never figured out why it happens. It looks a bit goofy in schedules. Any ideas?
  1. Double Door/ Single swing
    By billynutts in forum ACA/AMEP Styles Library
    Last Post: 2008-10-27, 06:00 PM
  2. Existing store front w/ a new door
    By Don Sutherland in forum Revit Architecture - General
    Last Post: 2007-05-17, 03:17 PM
  3. 2" door jamb and 4" door head?
    By ryant in forum ACA General
    Last Post: 2005-11-22, 03:25 AM
  4. Help, Does anybody had an adjustable swing double "glass' door.
    By cosmickingpin in forum Revit Architecture - Families
    Last Post: 2005-03-22, 12:52 PM
  5. Curtain Wall-Store Front Door
    By wjspence in forum Revit Architecture - General
    Last Post: 2003-08-21, 03:07 PM
