Results 1 to 10 of 17
Thread: Light Gage Metal Stud
    2004-12
    New Jersey
    179
    Default Light Gage Metal Stud
    Don't know if anyone is interested but I have a Mtl Stud family. Take a look and comment if you see errors.
    I used the SSMA catalog to get the properties and types. Currently we were only interested in the overall shape. I will calculate the Xcg later as well, but for now I set them all at 0.500" I was going to add the structural properties at a later time since the only program we have to design ltga is RAM Advanse and there is no API, the need was not there. I also left the two tag placeholders empty for now.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Light Gage Metal Stud
    ...Autodesk should pay you for that effort.
    2004-12
    New Jersey
    179
    I wont hold my breath
    Here's the track section
    2007-12
    21
    These are great. Thanks for the files. I'm new to revit so I'm wondering how you can uses these files in a vertical span capability. They work great in a horizontal application such as a floor framing but I would also like to use them in a vertical application. Any insight?
    2002-08
    Des Moines, IA
    38
    I have heard if you are on subscription you may download a family of lt ga mtl studs that includes all SSMA products.
    2004-12
    New Jersey
    179
    ..and they resemble the ones I sent up to autodesk.
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by phil.156294 View Post
    I looked at the family and the stud is modeled horizontally with "always vertical" checked in the family categories box. I'm not sure if unchecking that would let you rotate it vertically or not.
    But I'm curious as to why you would need to model metal studs? I've never modeled studs, ever. I've only drawn them in details with detail components. I do have a metal stud wall detail component that includes both top and bottom tracks.
    2015-11
    Fairbanks, AK
    136
    Quote Originally Posted by patricks View Post
    ... But I'm curious as to why you would need to model metal studs? I've never modeled studs, ever. I've only drawn them in details with detail components. I do have a metal stud wall detail component that includes both top and bottom tracks.
    If someone is using light gauge metal studs for a truss design, the ability to model them is important. It's faster to model them in Revit then send to your modeling software (Risa, etabs, etc...) then to build them in the modeling software (most of the time). I have been playing with this feature to test out some of the light gauge trusses that have been called out on older projects (mainly for practice on future projects).
    2004-12
    New Jersey
    179
    I needed to create and put these in our models due to client request. A part of our business is providing AE services to a modular fabricator. We are making not only field CD's but also each mod is fully detailed for the production line. Need to know every stud and it's length as well as the tubular frame and slabs.
    Normally I wouldn't do this or recommend.
    2007-05
    2
    This is more than likely a dumb question, but how do I load the information in the text file into the family file?
  1. LIGHT GAGE METAL TRUSSES ON COMPLEX ROOF
    By dbumgarner in forum Revit Structure - General
    Last Post: 2012-10-08, 08:59 PM
  2. Metal Stud Wall
    By andyhoman1550505 in forum Revit Structure - Families
    Last Post: 2012-04-24, 07:26 PM
  3. Metal stud DB rotate issue
    By beardking in forum Dynamic Blocks - Technical
    Last Post: 2010-06-08, 05:59 PM
  4. Light Gage Metal Truss
    By Mr Greg in forum Revit Structure - General
    Last Post: 2008-05-15, 05:10 PM
  5. Metal stud at the end of the wall as well as repeat every 16"
    By spddesigns in forum Dynamic Blocks - Technical
    Last Post: 2007-05-24, 02:59 PM
