Calvn_Swing
Here's what we do. The "possible rating" or "assembly rating" is and should be a type parameter. Why? Because a wall assembly with a 3 5/8 metal stud and one layer of 5/8" gypsum on each side will always have the same UL assembly rating. We use the built in type parameter "Fire Rating" for this value.
We then create in the project template a shared text instance parameter called Acoustic or Rated construction (you could do smoke or fire rated construction in your case). In a project, we either populate that field with an R or an A. That parameter is in our wall tags, and our code plan VG filter settings search for that parameter to enable graphic overrides in walls along with the Fire Rating parameter to know what it is rated for.
Make sense?
