Thread: RPC Trees
    2007-10
    9
    Default RPC Trees
    I have always wondered why RPC trees seem to do a pirouette when your camera moves by them in an animation. Does anyone know why this happens and how to stop it? I used to have alibrary of trees that I made by rendering each RPC and them mapping the image on to two 2D planes that I put together in a cross shape. This helped the "moving tree" problem, but I have since lost that library.
    I would like to use the RPC trees, but don't want them (or their shadows) to look like they are moving in an animation.
    I could stop if I wanted to dellis's Avatar
    2003-12
    Windsor, Ontario, Canada
    379
    Default Re: RPC Trees
    Select a tree and go to the motion tab....then look and see if there is a look at controller on the RPC tree for rotation. If thats what it is, then just change it to a normal Euler XYZ.
    2007-10
    9
    I did a test in an empty scene with only one tree and it looked fine. I ran an animation in a model i am working on and all of the trees do the dance. Could this have something to do with having the multiple RPC's in the scene? I didn't copy the trees around, I inserted them all individually. And I checked the controller, the rotation is set to Euler XYZ.
  1. Trees
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2007-10-22, 11:57 PM
  2. 2d Trees
    By dsw98 in forum Revit Architecture - General
    Last Post: 2007-07-20, 12:46 PM
  3. 3d trees
    By Joef in forum Revit Architecture - General
    Last Post: 2006-05-14, 05:53 PM
  4. 3d trees
    By john84851 in forum Revit - Rendering
    Last Post: 2005-05-09, 09:07 PM
