Thread: AEC Dimensions & Annotative Scaling
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Default AEC Dimensions & Annotative Scaling
    i am having trouble getting AEC Dimensions to display correctly when using an annotative dimension style. the dimension style we have works fine if i just run normal dimensions. everything scales and displays correctly. if i try to use AEC dims, the text shows up tiny and doesnt adjust based on scale. if i change the AEC dimstyle to a non-annotative style they work out just fine. im sure its something small i am just missing, but i dont know what it is.
    thanks.
    This aggression will not stand. Man.
    2006-04
    1,124
    Default Re: AEC Dimensions & Annotative Scaling
    this seems to be related to the paperspace text size box in the text style options. i changed it from 3/32" to 0" and it cleaned right up.
    2005-11
    Georgia
    12
    Cool Re: AEC Dimensions & Annotative Scaling
    I experienced the same thing. this is totally stupid. Is it because the dim object is annotative and the dim style is annotative and the text style is annotative. do they cancel each other out or something ? good grief, we should be able to setup all annotation objects as annotative and forget it. All this weird combination behavior is unproductive time.
    "my purpose is to challenge all to question" Pardue the philosopher
  1. 2011: Annotative scaling problem
    By petertanderson677259 in forum ACA General
    Last Post: 2011-07-10, 02:41 AM
  2. Annotative Scaling is BROKE
    By scott.jeffers in forum AutoCAD General
    Last Post: 2009-03-25, 04:13 PM
  3. Transition to Annotative Scaling
    By cj_follmer in forum CAD Management - General
    Last Post: 2008-01-30, 02:59 PM
  4. DBs & Annotative Scaling
    By .chad in forum Dynamic Blocks - Technical
    Last Post: 2007-08-14, 10:06 PM
  5. Concept of Annotative Scaling
    By rmk in forum AutoCAD Annotation
    Last Post: 2007-05-11, 03:08 AM
