Results 1 to 6 of 6
Thread: linked file not showing
    2007-08
    48
    Angry linked file not showing
    hi, ive linked a revit file and it only seems to show up in plans. and what shows up in plans is ONLY grids now.. all im trying to do is make a rendering of a new buiilding and show the old beuilding in the background... but i cant see model items from the link in ANY view.
    all my phases look fine and phase filters too.
    any thoughts? my boss wants me to do a rendering in 4 hours... im getting upset
    thanks
    shane
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: linked file not showing
    Check it's elevation relative to the main model it's linked in. Sounds like iIt might be below your main model's view range. Go to a 3d view and see if you can find it.
    2007-08
    48
    thats the problem.. its not visable in 3d or in any view except plan.. and in plan only grids are visable
    2003-05
    Waterville, Maine
    1,748
    If you are just seeing grids in plan view, and you've gone to the view / visibility dialog, clicked on the Revit Links tab, and checked to see if it's turned on, then it's probably way out there.
    Try this. Go to a 3d view, click the view menu, and then orient, and pick south.
    Once there, zoom to fit. If your screen looks blank, zoom in on the top and / or bottom to see if you can see either the main or linked model....
    Or, start a new project, and link in both models....and see if you can see them...
    2005-07
    Somewhere in the BIM world
    3,147
    If you have worksets enable, turn them all on in the 3D view
    2003-04
    Irvine, CA
    6,808
    This could be that the worksets that the project is using were created by un-checking the "Visible by default in all views". If so it won't be possible to display those worksets in the host project. They'd have to move everything to worksets that were not created that way. You could ask the firm that provided the model to confirm. Looks like we've missed the deadline. Did you figure it out?
  1. linked/imported CAD file not showing up
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2011-03-25, 04:03 PM
  2. Elements from a linked file not showing up
    By david_peterson in forum Revit Architecture - General
    Last Post: 2010-02-03, 07:52 PM
  3. Linked file not showing up?
    By tys90 in forum Revit MEP - General
    Last Post: 2009-09-15, 03:16 PM
  4. Spot elevations from linked file not showing up
    Last Post: 2009-01-09, 02:16 AM
  5. Replies: 0
    Last Post: 2007-12-20, 12:54 PM
