Thread: Snap only to Points in Current View
    2006-09
    12
    Unhappy Snap only to Points in Current View
    So I have a problem/gripe with Autocad. Its been annoying me for years, and this is the first that I'm complaining about it. Is there any way to force osnap to ONLY snap to points in the current viewing area? It is too often that I try to move a text box a little bit while zoomed in close, and WHAM, off the screen, undo undo undo, because my cursor was too close to a long line, and it end snapped 500 feet right..... Microstation (which I hate) does not do this.
    0,0,0 The Origin
    8,570
    Default Re: Snap only to Points in Current View
    You're not alone. AFAIK the answer is no.
    I set osnap to NONe or NEAr - when I remember.
    2006-09
    12
    eh, that's what I was afraid of... i'd say about 65% of the time i remember to hit F3 first....
    Wish List?
    2004-08
    Iron Station, NC
    3,198
    Quote Originally Posted by mbickerton View Post
    Wish List?
    only if there is a way to shut it off, I can think of times when I would like to be able to select points out of the current view.
  1. Object Snap Between Two Points
    Last Post: 2013-05-06, 03:55 PM
  2. Multi-View Block snap points
    By douglass in forum ACA General
    Last Post: 2012-08-16, 11:00 AM
  3. How to catch element snap points in a view for coordinates
    By cadorcl in forum Revit Structure - General
    Last Post: 2011-05-12, 09:19 AM
  4. Ability to snap to all objects in a 3D view, not just objects on the current reference plane
    Last Post: 2010-03-12, 06:09 AM
  5. Snap to current layer only
    Last Post: 2006-09-11, 04:46 PM
