Thread: Entity handles
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Default Entity handles
    I'm beginning a new coding project that will invove thousands of points. I have never really worked with handles before. Just for the record, my question is: is the entity handle a hex number? If I convert it to a decimal integer will it ever overflow?
    This code looks like it will work, or should I change it to Long?
    Dim DecHandle as Integer
    DecHandle = CInt("&H" & WorkPt.Handle)
    2000-01
    Seattle WA USA
    5,859
    Default Re: Entity handles
    To the API the Handle is a string. To convert the handle to something usable you should use the HandleToObject method on the document.
    R. Robert Bell
    Design Technology Manager
    Stantec
  1. Replies: 0
    Last Post: 2014-12-27, 08:59 PM
  2. Help with Handles!
    By dupuy77362646 in forum AutoLISP
    Last Post: 2013-03-03, 10:52 PM
  3. Stationary handles!
    By vgriffiths120838 in forum Dynamic Blocks - Technical
    Last Post: 2012-08-02, 09:24 AM
  4. Door handles
    By m_r_meza in forum Revit Architecture - General
    Last Post: 2005-08-11, 09:16 AM
  5. Proxy Entity Code 310 to Normal Entity
    By KevinBarnett in forum AutoCAD General
    Last Post: 2005-05-26, 07:21 AM
