This seems so strange - and I hope someone has run into this issue. We are relatively new to Revit, but have successfully made two workset enabled projects with a central file on our server and local files and all went smoothly.
Today I have tried to set a project up with a central file and it consistently comes back with "File Not Saved" when I try to save it as a central file. I am able to save a central file to my local drive, but not on the server. I even tried taking that central file I created on my local drive and moving it to the server, then saving as central and came back with the same error.
There isn't a block on the server since I am able to save general files and regular (non-workset enabled) Revit files to the server.
Does anyone have a clue what could be causing this? I am at a loss.
