Results 1 to 7 of 7
Thread: steel bracing visibitly issue
    I could stop if I wanted to bskripac's Avatar
    2002-04
    Columbus, Ohio
    212
    Default steel bracing visibitly issue
    I am having an issue with how the steel bracing members are reading in plan view. I have a tube steel bracing member modeled between column lines 1 and 2 and in my Level 1 floor plan it is showing up as though I was looking down on it from the floor above. My view range's cut plane seems to have no effect on this steel member. Even if I create a view range for that area it has no effect. If I cut a wall section through the tube steel it shows up correctly but I can seem to get that same sort of representation in my floor plan.
    Any ideas?
    I could stop if I wanted to Baldwin_4-6-0's Avatar
    2004-02
    384
    Default Re: steel bracing visibitly issue
    How do you want to see it?
    2002-04
    Columbus, Ohio
    212
    Just as though it were being cut by the Cut Plane for the rest of floor. I would love to have it look the same way as it is being cut in the section I created in the file.
    Any ideas?
    2005-07
    3,250
    The display representation of bracing is unaffected by the cut plane and it always shows in projection. If for some reason you want to see it exactly as cut, you'll have to use a different family category, such as a generic model. Most families show a cut representation as cut in the family and not as cut in the project (almost like a "symbol" representation). You might want to check out this thread:
    http://forums.augi.com/showthread.php?t=67500
    2002-04
    Columbus, Ohio
    212
    Smile Re: steel bracing visibitly issue
    Thanks for the help, that suggestion was what we actually moved forward with yesterday. We built a generic model family so we could see exactly where the bracing was coming through in plan. It just seemed weird that it would cut in section and not plan, but oh well...maybe in 2009...
    2004-02
    384
    It works by cutting a section, without making a new generic model family.
    2002-04
    Columbus, Ohio
    212
    That works just as it does in a vertical section, but how do I get this in the floor plan or are you suggesting using this view for a floor plan?
  1. 2013: Connection Between RC Column with Steel Bracing
    By krishnakumar in forum Revit Structure - General
    Last Post: 2013-05-09, 10:27 AM
  2. 2013: Help! Tower Bracing Issue
    By megan355111 in forum Revit Structure - Families
    Last Post: 2013-02-07, 11:51 AM
  3. Show steel X bracing as a single line in Fine Detail?
    By Dave F. in forum Revit Structure - General
    Last Post: 2009-03-18, 09:17 AM
  4. Structural bracing and architectural walls - display issue...
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2007-11-20, 11:45 PM
  5. YES / NO visibitly Paramaters Bad Buggy Behaviour?
    By Martin P in forum Revit Architecture - Families
    Last Post: 2007-09-06, 09:54 AM
