Thread: MIscellaneous - Deck Screw
    Active Member zorroxxxx's Avatar
    2002-12
    89
    Talking MIscellaneous - Deck Screw
    Hi,
    Here I experimented with the stretch and array parameters. I also added an alignment and look up parameters.
    Any feedback is welcome. Any ideas for improvement?
    Gary
    Active Member fkellogg's Avatar
    2005-09
    West Virginia, via Fayetteville, Arkansas
    82
    Default Re: MIscellaneous - Deck Screw
    I had a similar desire to have a screw . . . drawing.
    Mine is similar - I copied your alignment parameter idea. I'm sometimes having trouble with rotate and stetch in combination, and align works without trouble.
    I use a much simpler screw -fewer entities (79 vs 208 for a 3" screw) and snap points.
    Mine also sets below the surface a bit so I can hatch around it and it is a bit shorter so it does not poke thru.
    I made the stretch parameter have zero grips, so I just select from the lookup list -who gets custom length screws?
    2006-11
    Martinsburg, WV USA
    186
    Quote Originally Posted by fkellogg View Post
    Well put! I have been fussed enough about "I dont care how you draw it, but it better be purchasable and correct!". I have attached my version(s) of a wood screw as well.
  1. Replies: 16
    Last Post: 2011-05-03, 09:57 PM
  2. Does anyone have a Dynamic screw Block
    By pangell in forum Dynamic Blocks - Technical
    Last Post: 2006-09-13, 09:35 PM
  3. 3D Screw Flight Generation
    By shane.72538 in forum AutoCAD 3D (2006 or below)
    Last Post: 2004-08-02, 05:28 AM
  4. Draw a screw etc
    By engr_angelesdm in forum AutoCAD 3D (2006 or below)
    Last Post: 2004-07-31, 04:50 PM
