Thread: Flow Parameter in a custom mvpart
    All AUGI, all the time buzz's Avatar
    2007-10
    Tucson, Arizona
    613
    Default Flow Parameter in a custom mvpart
    I was bored tonight and wanted to see how close I could come to throwing the computer out the window, so I created a custom mvpart.
    I made rooftop units in various tonnages, each with a supply & return duct, as well as condensate drain and gas line connections.
    Everything works great, except that I can't seem to add a flow (CFM) parameter to the units. Diffusers have the Flow tab, and so do VAV boxes... how do I get that for my rooftop units?
    I tried adding a "custom data 1" parameter, naming it "Flow", giving it units of "CFM", and entering the values for each unit, but that doesn't quite do it...
    Perhaps throwing the computer out the window is the fix?
    -Buzz
    no trophy, no flowers, no flashbulbs, no line,
    he's haunted by something he cannot define...
    humble genius
    2007-10
    Tucson, Arizona
    613
    Default Re: Flow Parameter in a custom mvpart
    Perhaps some screen shots would help...
    -Buzz
    humble genius
    2002-09
    Madison, WI
    4,440
    Hi Buzz (sorry if that's not your real name)
    Please note that I've moved your thread here as I believe it is a better place.
    Thanks
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2007-10
    Tucson, Arizona
    613
    Cool, thanks Dave (and yeah my name is Buzz)
    humble genius
    2007-10
    Tucson, Arizona
    613
    In case anyone tries to do this too, I think I figured it out...
    While looking into changing the Part Type for a different mvpart I was creating (see this thread: http://forums.augi.com/showthread.php?t=70751), I decided to try changing the Type of part that the rooftop unit goes under.
    I had set it to be an Air Handling Unit > Roof Mounted AC Unit
    If I change it to be a VAV Box > RTU, it gives me the Flow tab
    Since a rooftop unit is not a VAV Box, this "fix" is not ideal, so if anyone knows of a better way of accomplishing this please let me know...
    -Buzz
    humble genius
  1. Zero flow from custom diffuser?
    By mike.dixon in forum Revit MEP - Families
    Last Post: 2009-11-18, 05:11 PM
  2. "Flow" parameter for Air Terminals?
    By archjake in forum Revit MEP - Families
    Last Post: 2009-09-28, 07:52 PM
  3. Do I need a custom parameter?
    By mattw in forum Revit MEP - General
    Last Post: 2009-04-02, 03:56 PM
  4. Custom mvpart properties
    By buzz in forum AMEP General
    Last Post: 2008-01-03, 03:32 PM
  5. Custom "Part Type" for a mvpart
    By buzz in forum Parts Builder
    Last Post: 2007-11-10, 04:14 AM
