Thread: Optional Infill Wall when using phases
    Wish List Administration
    2007-08
    603
    Default Optional Infill Wall when using phases
    Summary: Allow options to infilling the openings created by demolished doors/windows
    Description: When using phases, and demolishing a window or door, a infill wall is created by Revit.
    - There should be an option to not have the infill wall.
    - The Infill wall should be able to be changed to a different wall type.
    How Used: When using phases, and demolishing a window or door, a infill wall is created by Revit.
    Feature Affinity: Phasing
    Submitted By: Bret Thompson on September 13, 2007
    2007-10
    5
    Default Re: Optional Infill Wall when using phases
    In addition to infill options, the ability to set an openings' Phase independently from the host wall would be a beneficial.
    eg. Placing a wall opening in an existing wall does not show the opening portion as a demolished wall.
    Pittsburgh, PA USA
    1,906
    Currently, you can select the wall-infill, and change its style, phase and workset and its workset. This allows filtering so that the surface pattern of existing walls is turned off, while the infill portions show as hatched.
    2002-02
    St. Louis, MO
    4,695
    I'd be happy if the auto-infill feature just went away altogether. I always thought it was ill-conceived. When you demo a door in reality, the wall doesn't magiaclly heal itself. We should just deal with it as new construction.
    2015-12
    25
    You make an excellent point. I agree with you. Perhaps an option could pop up asking if you wanted an infill wall placed or not.
  1. 2011: Demolish Door, but no Wall infill
    By eric.110455 in forum Revit Architecture - General
    Last Post: 2020-01-25, 08:07 PM
  2. Wall styles in a Curtain Wall Infill
    By tra1133 in forum ACA General
    Last Post: 2012-08-03, 03:23 PM
  3. curtain walls with wall infill are joining?
    By Justin Marchiel in forum Revit Architecture - General
    Last Post: 2011-08-10, 02:04 PM
  4. Joining of New Wall & Infill Wall
    By joe.198711 in forum Revit Architecture - Tips & Tricks
    Last Post: 2009-09-25, 12:21 AM
  5. Curtain Wall with Door Infill Problem....
    By Marv Muston in forum Style Management
    Last Post: 2007-02-05, 05:19 PM
