Results 1 to 10 of 13
Thread: Export Layout Tab Names
    100 Club avdesign's Avatar
    2005-08
    STL Metro
    173
    Default Export Layout Tab Names
    Hey everybody,
    I did a search already and didn't find anything related to what I'd like to do.
    What I want to do is export the name of a single layout tab or multiple layout tabs to a text file. The one thing I don't want to use is Sheet set Manager. I there a way to do this or am I SOL.
    Turlock, CA
    5,489
    Default Re: Export Layout Tab Names
    Nothing built into acad, but lisp or vba can do it.
    C:> ED WORKING....
    Earth
    9,532
    Here is a quick routine to do this....
    (setq fn (strcat (getenv "temp") "\\" "layoutlist.txt")
          fp (open fn "w")
    (vlax-for x
    	  (vla-get-Layouts
    	    (vla-get-ActiveDocument
    	      (vlax-get-acad-object)
              (princ (vla-get-Name x) fp)
              (princ "\n" fp)
    (close fp)
    (startapp "notepad" fn)
    R.K. McSwain | CAD Panacea |
    2005-08
    STL Metro
    173
    Smile Re: Export Layout Tab Names
    Oh freakin' Sweet
    Thanks for that chunk of code.
    Earth
    9,532
    No problem. Have a good one.
    2004-06
    Slidell, Louisiana
    722
    Is that code vba or lisp? How would I save it and activate it?
    Earth
    9,532
    Lisp.
    Copy it to Notepad.
    Save as a file like "listlayouts.lsp" - to a directory that is in your support file search path
    When you need to run it, just load it like this (load "listlayouts")
    2004-06
    Slidell, Louisiana
    722
    Thanks R.K. I appreciate the info.
    Robert
    Does it work with acad 2008 vanilla. I copied it and saved it in the support directory, but when i loaded it i got this error: ; error: no function definition: VLAX-GET-ACAD-OBJECT. Not savvy with lisp, so i have no idea what this means.
    Earth
    9,532
    Sorry about that. Add (vl-load-com) to the top of the file.
    2004-06
    Slidell, Louisiana
    722
    Thanks, that worked just fine.
  1. Layout tabs names change when layout renamed in SSM
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2013-01-20, 05:07 AM
  2. Layout Tab Names as Fields
    By ron.hodkins in forum ACA General
    Last Post: 2008-06-23, 05:05 PM
  3. Colors on layout tab names
    Last Post: 2008-05-14, 07:07 PM
  4. Fields in layout names
    Last Post: 2006-03-27, 09:17 AM
  5. Publish layout tabs and layout tab names to PDF
    By dfuehrer in forum AutoCAD Plotting
    Last Post: 2005-11-09, 02:49 PM
