I am not going to explain what I need this for because it would take too much of everyones time. So, I am going to just dumb it down to the basics. I really hope someone will be able to help, it will make my work much nicer
i want to create 3 blocks that are nothing more than rectangles 2"x6". I'll call one block "A", and the other two "B" and "C". the dynamic properties of the blocks are simple, just a stretch mode that i can adjust the 6" dimension to whatever length i want. I dont want to change the 2" dimension. Inside each rectangle, I want an attribute that at some point i can label the block with a part mark.
Once i have all of my blocks stretched to the lengths i need, i would like to use EATTEXT to extract the block name, attribute value and the distances into a table. Keep in mind that i have not filled out any of the attributes in the blocks.
Up to this point its simple and im good to go.
But, once i have the table created, does anyone know of a way that i can fill in the blanks in the table under the attribute column, and have that information transfer to all of the blocks that line is referencing? I have an example attached..
