Thread: Baluster Panel Scaling of Pattern
    2004-05
    792
    Question Baluster Panel Scaling of Pattern
    We want to create a simulated wire mesh baluster panel. So far so good, we created it, added a model crosshatch of 2" x 2", good. Loaded it into our model at 1/8" - 1'-0".
    The mesh has now grown to about a 12" by 12" pattern not 2" as designed. Is there some scaling issues with model patterns? It was created at 3/4" -1'-0" default Family Editor size.
    When we scale out drawing up to 3/4" the mesh reads fine.
    Any ideas are welcome.
    2005-12
    86
    Default Re: Baluster Panel Scaling of Pattern
    Just tried it on our Metric RA: 50mm mesh as a model pattern seemed to work fine, see attached.
    You've double-checked that it's a model pattern not a drafting pattern, of course. But it's behaving like a drafting pattern. Sounds like an issue for support?
    2004-05
    792
    Yeah , I thik I will try metric to see if it's an imperial problem only.
  1. 2013: Baluster Panel Transitions
    By gbrl.frdmn344420 in forum Revit Architecture - Families
    Last Post: 2014-06-20, 04:17 PM
  2. 2013: Adaptive Curtain Panel pattern problem? Curtain Panel pattern overlaps on certain patterns
    By robertlevy493178 in forum Revit Architecture - Families
    Last Post: 2012-08-31, 04:56 PM
  3. Where is Metric Baluster-Panel Template
    By Jimidy in forum Revit Architecture - General
    Last Post: 2011-10-11, 08:14 AM
  4. Baluster Panel Question
    By craighowie in forum Revit Architecture - General
    Last Post: 2010-08-26, 07:25 AM
  5. Baluster, Baluster - Post and Baluster - Panel
    By phyllisr in forum Revit Architecture - Families
    Last Post: 2009-10-15, 03:27 PM
