Thread: layout tabs
    2004-03
    Jacksonville, FL
    8
    0 Did you find this post helpful? Yes
    Question layout tabs
    Is there a shorthand command to switch between layout tabs for LD3 or Acad-2002;
    similar to the "ctrl page up-down" feature in 2004?
    -Joe Williams
    Jacksonville, FL
    The Silent Type
    2015-12
    Arizona
    2,337
    Default Re: layout tabs
    Good question, I went and looked and found
    nothing helpful
    There is CTAB only you have to provide the tab name
    and LAYOUT>Set, same input format.
    2015-12
    Northern California
    581
    Quote Originally Posted by jwilliams.67235
    -Joe Williams
    Jacksonville, FL
    Here's a few little routines to do this. First, save these to a.mnl file name of your choosing (I tested this with "mymenu.mnl"). Then, in a matching name .mnu file (again, mine was mymenu.mnu) place these lines:
    ***MENUGROUP=Mymenu //use the name of your file here
    ***ACCELERATORS
    [CONTROL + "LEFT"]^C^C(prev_tab)
    [CONTROL + "RIGHT"]^C^C(next_tab)
    This makes the CTRL + leftarrow go down in the tab order and CTRL + right arrow go up
    (defun create_tab_list (/ layouts)
      (setq layouts (dictsearch (namedobjdict) "acad_layout"))
      (setq layouts (member (assoc 3 layouts) layouts)
    	*tab_list* nil)
      (while layouts
        (if (not (= (cdr (car layouts)) "Model"))
          (setq *tab_list* (cons (cons (cdr (assoc 71 (entget (cdr (car (cdr layouts)))))) (cdr (car layouts))) *tab_list*))
        (setq layouts (cdr (cdr layouts)))
      (setq *tab_list* (vl-sort *tab_list* '(lambda (x y)
    					 (< (car x) (car y))))
    (defun next_tab (/ idx count)
      (create_tab_list)
      (setq count 0)
      (foreach x *tab_list*
        (if (= (cdr x) (getvar "ctab"))
          (setq idx count)
        (setq count (1+ count))
      (setq count idx)
      (if (= count (1- (length *tab_list*)))
        (setq count -1)
      (setvar "ctab" (cdr (nth (1+ count) *tab_list*)))
    (defun prev_tab (/ idx count)
      (create_tab_list)
      (setq count 0)
          (setq idx count)
      (setq count idx)
      (if (= count 0)
        (setq count (length *tab_list*))
      (setvar "ctab" (cdr (nth (1- count) *tab_list*)))
    Enjoy!
    Jeff
    2004-12
    153
    what about something using ctl+ something??? Like being able to switch between drawings using ctl + tab?? I've seen that ctrl+r will do it, but it won't work for me...
  1. 2015: layout tabs
    By kelly803934 in forum ACA General
    Last Post: 2014-10-13, 03:36 PM
  2. Layout tabs names change when layout renamed in SSM
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2013-01-20, 05:07 AM
  3. Layout tabs
    By york in forum CAD Management - General
    Last Post: 2008-01-07, 12:43 PM
  4. How do others use Layout Tabs
    By mwilson in forum CAD Management - General
    Last Post: 2006-11-02, 07:12 PM
  5. Publish layout tabs and layout tab names to PDF
    By dfuehrer in forum AutoCAD Plotting
    Last Post: 2005-11-09, 02:49 PM
