Thread: Heidi driver load failure w/ Design Center
    2004-12
    126
    Default Heidi driver load failure w/ Design Center
    All of a sudden, everytime I use Design center I get an error box (attached image) and hardware acceleration diable warning when I go to performance ture/systmes tab to investigate. This happens when I try to drag the DC image into the drawing - this never used to happen. What does it all mean?
    Mechanical Desktop masquerading as ACAD2008 (part of Inventor 2008 Series install), Win XP Pro SP2, Nvidia FX3450/4000SDI, ForceWare version 91.36, Zeon @ 2Ghz, 3GB Ram
    Thanks
    Mike Youla
    2004-08
    Hartford, Michigan
    3,086
    Default Re: Heidi driver load failure w/ Design Center
    Quote Originally Posted by Mike Y View Post
    Thanks
    does it only happen when you drag, or does it happen when you double click the item for it to ask you to select the insertion point.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    2004-12
    126
    Happens both ways. If I start a session of Autocad from scratch, no other session open, and drag, I get message.
    If I start a session of Autocad from scratch, no other session open, and double click, I get same message.
    Thanks for your help,
    Mike
    Mike Youla
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    I had a similar problem start after applying SP1 for Civil-3D.
    I got it to clear up by simply going into 3DCONFIG and turning off all hardware acceleration. Then I rebooted Autocad, went back into 3DCONFIG and turned hardware acceleration back on. Everything has been fine ever since.
    This issue hit all our installations of Civil-3D that use nVidia Quadro graphics cards. However, it did not hit Land Desktop. We do not use any other Autocad products, so don't know if this will help with your version.
  1. Heidi Driver
    By tonyv in forum CAD Management - General
    Last Post: 2012-05-04, 12:28 PM
  2. 2012: AutoCAD - 2012 - Heidi Driver Crash
    By gfreddog in forum AutoCAD General
    Last Post: 2012-03-23, 02:25 PM
  3. Heidi driver fails to load
    By kleenhippie in forum AMEP General
    Last Post: 2010-07-14, 01:16 PM
  4. Looking for a Heidi driver for a HP DesignJet 500
    By jonathan_fairholm in forum AutoCAD Plotting
    Last Post: 2007-04-08, 05:05 AM
