Results 1 to 8 of 8
Thread: Elevation Boundary
    2007-06
    9
    Default Elevation Boundary
    Is there a way to force the elevation boundary to plot? My interior elevations looks incomplete when I plot them out. I tried placing break lines, but it doesn't work.
    Eric
    2007-09
    19
    Default Re: Elevation Boundary
    most people increase the crop region then draw a masking region using wide lines to trace the perimeter of the view then invisible beyond that to "white out the extra"
    2007-06
    9
    Quote Originally Posted by sccbrown View Post
    Thanks for the response! It's the little things like this that can drive someone crazy! There should be an option to plot the crop region. Maybe something for the wishlist.
    2005-07
    3,220
    The option already exists (uncheck the "Hide Crop Boundary" option before printing).
    Member ssmith.124120's Avatar
    2006-10
    Dallas, TX
    17
    That works great, but is there a way to make the crop boundary line a thicker line weight?
    Also, on a side note, I am having trouble dimensioning to the edge of my interior elevations when the crop boundary is snapped to the extent of the room. All of the dims disappear when the wall is at the edge of the crop boundary. Is there a way to make these dims visible again?
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by ssmith.124120 View Post
    The problem is that the Crop region won't allow dimensions coinciding with its edges. The dimensions will disappear. You may want to consider using a Mask region. That will also solve your problem of having thicker lines.
    Andre Carvalho
    2004-06
    Memphis TN area
    6,700
    I always drag the crop region so that is just barely shows the cut line of the wall face, floor, and ceiling. Then there is no need for crop regions to print, and you will have thick lines around the elevation.
    AERC, PLLC
    Hernando, Mississippi
    Active Member wblaney's Avatar
    2007-06
    54
    you can select the crop boundary and use the graphic overrides to change the lineweight color and linetype of the boundary. Not sure how to solve the problem of dimensions disappearing though...
    Weston Blaney, LEED AP
    Carson Design Associates
    Austin, TX 78759
    512-977-0520
  1. Replies: 0
    Last Post: 2012-03-29, 05:35 AM
  2. Elevation Crop Boundary Gone Mad
    By jayc in forum Revit Architecture - General
    Last Post: 2010-06-04, 12:10 PM
  3. Replies: 9
    Last Post: 2006-08-24, 11:46 AM
  4. Boundary intersects itself. Surface boundary could not be applied.
    By brian.59027 in forum Land Desktop - General
    Last Post: 2005-10-13, 02:35 PM
  5. Interior Elevation Outline Boundary
    By studio3p in forum Revit Architecture - General
    Last Post: 2003-10-16, 09:58 AM
