Originally Posted by
sfaust
you should select elements, then go to Tools->External Tools-> Selection Sets. It should pop up a dialog box with the existing selection sets listed (which will be none the first time). There is a place at the bottom to type in a name and create a selection set from the elements you currently have selected. After that, it should show up in the list of selection sets at the top and you can select it and hit "select elements".
Does this not work for you? It's working correctly in 2008 and 2009 for me...
