Results 1 to 10 of 11
Thread: Text Wrap in Dimensions
    ACAD Wish List Administration
    1,920
    Default Text Wrap in Dimensions
    Summary: The ability to set a width for dimension text to allow for text wrap.
    Description: Dimension need to contain text wrap! The text in a dimension should have same capability as mtext!
    How Used: had functionality
    Feature Affinity: Dimensions
    Submitted By: michael shick on October 18, 2007
    2012-02
    82
    Default Re: Text Wrap in Dimensions
    If you add "\B" (ignore the quotation marks) to the end of the text whie using Textedit you can get the text to wrap
    0,0,0 The Origin
    8,570
    If you add "\X" (ignore the quotation marks) anywhere within the text, the text splits above/below the dimension line.
    Cairo - no, not Illinois
    5,069
    or \P to force a linebreak where you want one
    2005-11
    51
    The company I work for uses text above the dimension line and the problem is that if you add a second line of text the entire group re-centers on the dimension line instead of the dimension staying above and text below. So many little irritations like that would make so many users happy to just have a "Yeah we fixed that" release.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by CAD_monkey View Post
    Look into using "\N" and "\X" (no quotes) to separate the dimesion from the notes.
    "\X" after the dimension gives the result you describe.
    edit: did you read the posts above?
    2005-11
    51
    Only the first \X delivers any result, \N and \P no longer work for me in Acad 2012, Enter will generate a second line of text but makes the dimension text location unstable. It is not often that I need to add a second line of text under a dimension but if Autocad is going to make it possible to do then they should make it stable. The only place the two lines of text works is in the Autocad approved locations of justified left, right or home. Attempting to move the dimension off just a little bit returns inconsistent results. See the attachment.Capture.PNG
    0,0,0 The Origin
    8,570
    Yep. "\X" only works to split above/below the dimension line.
    I agree that further split text is unstable when moved away from it's default position and that should be resolved.
    in the upper right corner
    3,508
    Maybe you've explained it before, but why can't you simple do the "\X" after the dimension and a hard return after that?
    Even if you move the dimension and "reset text position" it goes back as desired.
    <>\XTYP<enter>TEST
    0,0,0 The Origin
    8,570
    AIUI, it's really a different wish from that stated - and it's really a request for a fix, not a new feature.
    If you drag the dim text in your sample away from it's default position, it's quite likely that the line breaks will not remain constant.
    It's been like that for many releases.
  1. Wrap text in labels?
    By tomm in forum Revit Architecture - General
    Last Post: 2018-08-17, 01:38 PM
  2. Text wrap not working
    By M. Kubitza in forum Dynamic Blocks - Technical
    Last Post: 2009-10-22, 02:54 AM
  3. Wrap of Attribute Text
    By arshadmirza786 in forum AutoCAD General
    Last Post: 2005-04-15, 10:14 AM
  4. Don't wrap text, wrap dim, then undo it.
    By JASONM30395 in forum AutoCAD Tips & Tricks
    Last Post: 2005-03-04, 09:26 PM
  5. Text Wrap for Dimensions
    By keelay711 in forum AutoCAD Wish List
    Last Post: 2005-01-04, 09:58 PM
