Is there a lisp or shortcut to convert a multiple line mtext to a single line mtext?
Your help is greatly appreciated.
Thank you.
Craig II <><
Thank you.
Craig II <><
Thank you for your reply.
I don't know why I didn't think of it earlier, explode and convert back to mtext.
Easy as that.
Take Care.
Yes the above answer is ok if you do not have any fields in text, but how to do that with mtext containing fields so the fields stay fields?!
Extract the string (assoc 1 (entget <ename>)) and put it back, then explode.
Code:this.Mode = Modes.ProfessorChaos;Code:(defun c:FOO (/ ss oldEnt eData asso eName) (if (setq ss (ssget ":S:E:L" '((0 . "MTEXT")))) (progn (setq oldEnt (entlast)) (entmod (subst (cons 1 (cdr (setq asso (assoc 1 (setq eData (entget (ssname ss 0))))) ) ) asso eData ) ) (command "._explode" ss) (setq eName oldEnt) (while (and (setq eName (entnext eName)) (= "TEXT" (cdr (assoc 0 (entget eName)))) ) (command "txt2mtxt" eName "") ) (setq eName oldEnt) (while (setq eName (entnext eName)) (entmod (subst (cons 41 (* 0.0 (cdr (setq asso (assoc 41 (setq eData (entget eName))) ) ) ) ) asso eData ) ) ) ) ) (princ) )
Computer Specs:
... Just demonstrating, which regretfully doesn't do this:
... And I didn't know that:
... So, cheers... You know, for that.
Computer Specs:
