Thread: Network Support Files and a Slow(er) Network?
    I could stop if I wanted to chillme1's Avatar
    2006-05
    TN
    244
    Default Network Support Files and a Slow(er) Network?
    How do you do this....?
    In the interest of standardizing CADD by pushing some or all support files to the network - YET, keeping Autodesk app.'s (AutoCAD 2k8-(1) seat, 2k7 LT-(6) seats, TrueView) clicking faster in a small office:
    Which support files are best left on the network? which on the local drive?
    Also, reasons for the above would give me a better understanding.
    My initial network support file assignment tests showed a warning message when I assigned (I believe it was) the 'temporary file' to the network location. That occurence, along with relative INEXPERIENCE about this subject, lead me to assigning only the following:
    NETWORK
    Plotting support files (.ctb, .stb, .pc3, etc.)
    LOCAL
    All others
    Thanks for your input.
    Clint Hill
    Sr. Mechanical Designer/ CAD Operatior
    Chemical Process Plant Design / Machine + Tool & Die Design
    3D Intelligent Modeling & AUGI Fan
    Houston
    7,520
    Default Re: Network Support Files and a Slow(er) Network?
    I think it's more of a question of what are you trying to standardize. If network speed is an issue - then you should deal with that - not limit what you can standardize.
    We share things like "acad.lsp", "acaddoc.lsp", "acad.pat", "acad.lin", "acad.pgp", the drawing templates, fonts, menus, icons, toolpalettes, PC3 and PMP files, CTB files, shape (SHX) files, etc.
    2006-05
    TN
    244
    Wink Re: Network Support Files and a Slow(er) Network?
    Thanks. So, any other support file set up produces NO warning messages.....
    EXCEPT FOR....
    the warning message I received when assigning the 'temporary file' support path to the network. I suppose that's silly to start with. Just my luck...
    I will give it this (networking support files) another attempt and will prove this out when I go there in a couple of days.
    P.S.: I only do contract work there (about 40 hrs. / month via my employer)
    Clint Hill
    Houston
    7,520
    Yea, the TEMP folder should be local IMO. No reason to point that to a network share.
    2006-05
    TN
    244
    Thanks. ALSO,...thanks many times over for your clear tutorials on customizing file support paths and "setting support paths via lisp". There next on my TO DO list since I have this issue nailed down!
    That will do me.
    Clint Hill
  1. Network Support files centralisation
    By dphillips.115498 in forum AutoCAD Customization
    Last Post: 2008-10-31, 03:57 PM
  2. Replies: 15
    Last Post: 2008-07-02, 10:13 PM
  3. Replies: 17
    Last Post: 2008-06-11, 01:15 PM
  4. RE: Which support files should be located on the network?
    By eleonard in forum AutoCAD Customization
    Last Post: 2007-03-06, 07:43 PM
  5. Replies: 0
    Last Post: 2005-08-30, 06:58 PM
