Thread: Daylight not behaving correctly
    100 Club KansasCAD's Avatar
    2002-02
    Derby, Kansas
    114
    Default Daylight not behaving correctly
    Hello,
    I have a corridor that I am having a problem with. I have a "Daylight General" attached to back of curb. The Cut & fill for Slope 1 are set to 48:1 for a distance of 6'. For the majority of the corridor it behaves correctly. But then all of a sudden it gets sucked closer to the back of curb. I have double checked the targets and I don't seem to have anything that would be causing this. Any Ideas. It is a rather large drawing so I don't think I can upload it. Would a snapshot of the corridor help at all? I just tried to adjust the frequency to a smaller distance but I still get the same areas being closer to the back of curb.
    Daryl
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    Default Re: Daylight not behaving correctly
    If it is behaving properly for the majority of the corridor then I would perform a closer analysis of the target in the area where it is not.
    2006-12
    Loveland, CO
    734
    My guess would be that those areas where it is being "sucked" in are areas that exceed the cut/fill depths for the flat slopes. In your sub properties, make sure you cut/fill depths for flat slopes are set to a suitable depth for your design.
    2008-03
    Maryland
    54
    for the areas that are giving you trouble, create a different region and modify your range of stationing. copy the assembly and edit a few parameters that would meet your needs.. if it's in the tighter areas, you may need to take more samples to get desired effect. It's simple enough to just copy your assembly and just add it to the corridor and specify the ranges rather than trying to do it in one-go.
  1. Replies: 0
    Last Post: 2014-12-01, 03:22 AM
  2. 2014: Revit Keynote Legends not behaving correctly on different sheets
    By Kunnasm in forum Revit Architecture - General
    Last Post: 2013-09-13, 12:15 AM
  3. Microstation export isn't behaving
    By dwescott in forum AutoCAD General
    Last Post: 2010-08-31, 06:39 PM
  4. References not behaving
    By barrie.sharp in forum Revit Architecture - Families
    Last Post: 2010-06-18, 08:39 AM
  5. Linetypes between DWG's not behaving themselves
    By r_soula in forum AutoCAD General
    Last Post: 2007-03-22, 07:38 AM
