Results 1 to 9 of 9
Thread: How do you move layouts from drawing to drawing?
    2007-10
    4
    Question How do you move layouts from drawing to drawing?
    I have a project that I am altering and all the layouts were done in seperate dwg files. I want to move them all into one drawing so as to eliminate unwanted files. I tried the sheet set manager, but all it does is give links to where the seperate dwg files are located.
    2005-07
    2,356
    Default Re: How do you move layouts from drawing to drawing?
    Quote Originally Posted by javankoehn View Post
    You can transfer page setups via the Design Centre (ctrl+2).
    2005-06
    in the upper right corner
    3,507
    You can drag and drop layouts with design center (ctrl+2), it's a good idea to name your layouts accordingly.
    Turlock, CA
    6,420
    Another method.
    Add a layout to the desired dwg. Use the "Copy with base point" command using 0,0 as a reference and past it to 0,0 of the new dwg.
    C:> ED WORKING....
    LinkedIn
    2005-07
    2,356
    Another method.
    Do you mean copy the paperspace contents of a layout to another using a base point?
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    and there is always the old school way...
    _layout
    Template
    (select the dwg that the desired layout is in) click select
    (select the desired layout) click ok
    But obviously with the design center drag and drop is by far faster
    125
    What do you consider "unwanted files"? We have a file for each sheet, with some files having multiple sheets (layouts), elevations for example. Having a file for each sheet is not necessarily a bad thing. As for coping layouts you do that via design center, as mentioned. Note that if you copy a layout you may not see any objects in the vport unless the objects said vport is looking at are also in the file.
    ACote
    Turlock, CA
    6,420
    Quote Originally Posted by Steve.Sanderson(UK) View Post
    Yes, they were asking how to consolidate Layouts (not page setups) from multiple dwgs, the layouts being in different dwgs.
    C:> ED WORKING....
    LinkedIn
    2001-04
    127
    You can copy the model space entities using "copy with base point" then paste in the new drawing using "paste to original coordinates". Then copy the paperspace viewport anywhere in the new paperspace. Just realize that the viewport comes into the new drawing with the display turned off (at least mine does). So you'll have to highlight the viewport, right click and select "Display viewport objects" and click on "Yes"
    Works for me!
    Tom
  1. One drawing from many layouts
    Last Post: 2013-02-08, 09:46 AM
  2. 2011: Layouts and Drawing Management
    By tim.j.sparks in forum AutoCAD General
    Last Post: 2010-08-06, 10:21 PM
  3. Drawing Scales in Layouts
    By stun_hands in forum AutoCAD General
    Last Post: 2006-12-11, 11:27 AM
  4. copying layouts from one drawing to another
    By sgroff in forum VBA/COM Interop
    Last Post: 2006-11-04, 10:07 PM
  5. making 2D drawing from 3D in layouts
    By vishms22 in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-06-23, 09:53 AM
