Results 1 to 10 of 12
Thread: Exploding dynamic blocks w/ a flip parameter
    100 Club wroebuck's Avatar
    2004-07
    Chico, CA
    148
    Default Exploding dynamic blocks w/ a flip parameter
    Ok has anyone seen this or fixed this issue? I have a dynamic block with a flip parameter. If a drafter, used the mirror command on the block vs using the flip parameter; when you explode the block it resets back. I noticed, depending on which direction the block is mirrored, the X or Y scale factor will go to a negative value. If poly lines are involved, they also are exploded too.
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Exploding dynamic blocks w/ a flip parameter
    Quote Originally Posted by wroebuck View Post
    nope, I haven't. does using "BURST" make a difference?
    S&D DB Sharing Forum
    2004-07
    Chico, CA
    148
    Nope, that is what we are actually using to explode the blocks with. that way if there were attributes, they just explode to the value. This is wierd.
    All AUGI, all the time jmctamney's Avatar
    Blue Springs, MO
    656
    I hope Matt Murphy isn't listening. He doesn't like the "E" word
    2004-07
    Chico, CA
    148
    I've noticed that it is with all dynamic blocks. Mirror & explode(burst) a bad combination. We explode dynamic blocks here as much as we manipulate them, for multiple reasons. I am huge FOR nesting dynamic blocks. Yes there are quirks, but no more than dealing with attributes.
    2004-07
    Chico, CA
    148
    This is bigger than I thought. If you do explode the dyn block that has a negative X or Y scale values, it will force them both positive & change the positive Z scale value to negative. I have no idea where to post this issue now.
    2001-12
    Rochester, MN
    2,561
    do you have or know a programmer? maybe redefine the mirror command to recognize a DB and not allow a mirror action to be executed on one?
    i've toyed with that idea for certain DB's and tables for the explode command here.
    2001-12
    Rochester, MN
    2,561
    i'm assuming you have "uniformly scaled" option checked for your DB's?
    2004-07
    Chico, CA
    148
    Yes I have access to multiple programmers. That is a very good idea about the mirror command. Although we'll make it a custom routine so we can use it from here on out independently of the version of Autocad. As far as the uniformly scaled, I've tried both with the same result. I believe Autocad has always handled blocks like so, I just was un aware of it until now. Thanks for all of your help.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,186
    AutoCAD 2008 - English SP1
    Every insert I tested exploded as expected -- flipped, -1 x-scale, etc. So , no problem, here.
  1. Non Exploding Blocks
    By Shashikant in forum AutoLISP
    Last Post: 2011-05-02, 01:24 PM
  2. Exploding blocks that can't be exploded
    By larry.111254 in forum AutoCAD LT - General
    Last Post: 2010-10-18, 10:36 PM
  3. Insert dynamic block without exploding
    By curtis.hatfield in forum Dynamic Blocks - Technical
    Last Post: 2009-10-26, 04:56 PM
  4. Exploding blocks
    By Colin.Taggart in forum AutoCAD LT - General
    Last Post: 2007-07-17, 07:18 PM
  5. Exploding Blocks
    By lambertm in forum VBA/COM Interop
    Last Post: 2004-08-19, 07:52 AM
