Results 1 to 10 of 11
Thread: DB scaling problem
    2006-08
    Lake Charles, La.
    277
    Red face DB scaling problem
    I have a door that is a DB. As I insert it into my drawing, it is automatically scaled 25.33 times what it was created at. I've checked all scale values in the block editor and in the drawing and everything seems to be fine. The door width table shows the door to be a 36" door, but it measures out at 76' and change. I'm a bit of a neophyte when it comes to Dynamic Blocks, however I'm learning. I did not create this. I'm using it to learn as I create my own. What am I doing wrong with this block?
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: DB scaling problem
    In the block editor, with nothing selected, what does the Properties palette show as the block's units?
    sounds like an imperial / metric conversion of sorts...
    S&D DB Sharing Forum
    2006-08
    Lake Charles, La.
    277
    In units, it shows 'inches'. Here is the block if you'd like to take a look.
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by cwjean76 View Post
    what about the host drawing? (UNITS)
    as a general rule, i always make my blocks 'unitless'
    2006-08
    Lake Charles, La.
    277
    Quote Originally Posted by Chris.N View Post
    That was it. For some reason, UNITS was set to millimeters. I simply set it to inches and it then inserted properly. Thanks. Just out of curiousity, why do you set yours to unitless?
    2001-12
    Rochester, MN
    2,561
    those units are there for automatic scaling, like you discovered. setting them to 'unitless' nullifies that function. (most of mine are true size, and i've yet to explore metric anyway)
    my discipline is architectural, but am in a mostly civil firm. if i want it scaled to match the file units, i know it's either 1/12, or 12 for a scale factor, and prefer to do so manually.
    2007-05
    Chicago, Illinois
    194
    I'm in favor of using the correct units of the block. As long as you choose the units you are actually working in it should always scale appropriately. I draw my blocks in inches, so I specify inches for the units. This way if we need to insert the blocks into a drawing that uses metric it will give me a properly scaled door instead of a thirty-six meter door (or thirty-six millimeters).
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by mockdeep View Post
    if that ever happens, i'll make a seperate metric library.
    2007-05
    Chicago, Illinois
    194
    I guess the benefit is that it saves you the trouble of having to have two separate libraries. Oh, well. To each his own.
    2001-12
    Rochester, MN
    2,561
    i guess i've never really thought about it. around here, there's very little demand for metric. Tried it once, client made us change it back after all the bids came in thru the roof.
  1. 2014: scaling problem
    By rmk in forum AutoCAD Civil 3D - General
    Last Post: 2015-02-25, 08:05 PM
  2. Scaling problem in ASD
    By svemidobroideosimljubavi987591 in forum AutoCAD Structural Detailing
    Last Post: 2012-11-12, 08:56 AM
  3. ARGH. Scaling problem.
    By stannoman in forum 3ds Max - General
    Last Post: 2009-07-13, 02:35 PM
  4. Scaling Problem?
    By Chuckyd67 in forum ACA General
    Last Post: 2007-05-08, 04:49 PM
  5. viewport scaling problem
    By xiiisiecle in forum AutoCAD General
    Last Post: 2005-09-07, 12:34 AM
