Results 1 to 10 of 14
Thread: Can't select a view on a sheet.
    2006-10
    31
    Default Can't select a view on a sheet.
    Ok, I must be missing something totally obvious. I placed a view on a sheet and now I can't select the view. I need to move it. I can select the title block, but not the view. I searched but couldn't find any other thread on this. Has this happened to any of you? I've got to be missing something. Right?
    All AUGI, all the time Henry D's Avatar
    2003-05
    Fairfield, Iowa
    669
    Default Re: Can't select a view on a sheet.
    Is your view locked by any chance?
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    In your project browser, expand the sheets branch and then expand the Sheet branch that the view is on. Try selecting the view in question under that sheet. What happens?
    2006-10
    31
    Quote Originally Posted by Henry D View Post
    Locked? I didn't know that you could lock a view. How do I check that?
    Quote Originally Posted by rkitect View Post
    Ok. After, selecting the name of the view under the sheet, the view name turns blue. What next?
    Moderator JamesVan's Avatar
    2016-01
    New York, NY
    624
    Working on this very thing this afternoon. I found that if a view on a sheet is just about exactly coexistant with the titleblock box, you might have trouble selecting it - you'll get the titleblock first. Solution...use the TAB key to cycle down to the view.
    Do you have hidden lines or reference lines in your titleblock? I have reference lines in mine to allow for drawing the UDS grids.
    We are the music makers...we are the dreamers of dreams.
    All Things BIM
    Visit the Revit Community Home Page
    2003-05
    Fairfield, Iowa
    669
    Quote Originally Posted by SmartAlx View Post
    You can pin the view on the sheet. I mentioned this possibility because often I find that nothing happens when I am trying to edit an object and it's because it's locked and I can't see the pin.
    This probably isn't what's happening, because a pin is usually very visible when a view is pinned to a sheet...anyway look to see if there are any pins.
    2005-07
    3,250
    If you still can't grab the view per James' post, select the titleblock and hide it temporarily (HH). Now you should be able to pick your view easily...if not there must be something else. Another thing you can try is to expand the sheet tree to list the views on the sheet. Then select the view, right click and select "Remove from Sheet". Then place it back where you want it.
    2006-10
    31
    Angry Re: Can't select a view on a sheet.
    Sorry, none of these are solutions. I tried them all long before I posted this question. And replacing the view is a last resort. I took a long time placing this view in this spot since Revit sux at placing things on sheets precisely. I only need to move it a few nudges to the right. Easy to do. Well, it should be. Not anymore. There must be a bug.
    I just have to do what dbaldacchino said and continue hating this buggy incomplete program.
    I think I'll ask my IT/Revit "experts" and maybe they'll send in a bug report.
    Thanks for your help guys.
    2005-07
    3,250
    So by temporarily hiding the titleblock, you still can't grab the view, even by tabbing? Have you tried zooming out really far to make sure you are grabbing it? I've had cases where the view extents were so huge that it seemed the view wasn't selecting, where it actually was (it also helps to keep your eye on the status bar when doing this).
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    See here. This is a possibility.
  1. Random detail on sheet - can't select it
    By CADMama in forum Revit Architecture - General
    Last Post: 2012-11-07, 09:50 PM
  2. Replies: 0
    Last Post: 2012-03-01, 08:03 PM
  3. Sheet View changed to Drafting View; how do I get my sheet back?
    By lzaras in forum Revit Architecture - General
    Last Post: 2011-02-25, 08:09 PM
  4. Printed Sheet Margin is Much Wider Than Sheet View
    By MP7 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2010-01-04, 05:02 PM
  5. Select Block by custom sheet set property?
    By brandonc in forum AutoCAD Fields
    Last Post: 2007-05-01, 05:19 PM
