I'm attempting to set up a DB(with several fire alarm symbols) to utilize in a riser diagram. I've set it up with an array action, which works fine with two exceptions:
(1) As it arrays, it doesn't allow me to select each independent symbol to change it as needed. Only the first symbol has the visibility node available to change the symbol and when you do change it, the entire line of symbols change as well.
(2) Also, the array action only is available to me in one visibility mode. Do I need to set up an array up for each separate visibility mode?
I've attached the block for anyone interested in helping me understand what it is that I'm doing wrong here.
