Thread: Special Railing family?
    Modérateur Forum Français Pierre-Nelson NAVARRA's Avatar
    2007-10
    Nantes (France)
    531
    Default Special Railing family?
    Hi,
    I'd like to make a special railing.
    Like the file called "sample.jpg" in attach'ment.
    Is it possible to do this with a railing family.
    The aim is to have a kind of texture wich can be repeating following a simple line.
    Sample of texture in file called "railing" in attach'ment.
    Cheers.
    2007-10
    Nantes (France)
    531
    Unhappy Re: Special Railing family?
    Any solution?
    2015-12
    Vancouver, BC Canada
    3,753
    Default Re: Special Railing family?
    You need to create the 'reed' elements as your baluster panel.
    Unless you really need this to be 3D for rendering purposes I would suggest you create your baluster panels using model lines rather than solid objects. It might reduce model overhead if you have a lot of this railing in your project
    Last edited by Dimitri Harvalias; 2007-12-12 at 08:35 AM. Reason: Image added and alternate solution provided
    I could stop if I wanted to rkitect's Avatar
    2006-01
    449
    I agree with the panel method. Model a panel to contain your reed elements and they will repeat when you use that panel in your railing assembly. Let us know how it turns out!
  1. 2014: Baluster family categories and railing creation
    By CBroda in forum Revit Architecture - Families
    Last Post: 2013-10-25, 03:24 PM
  2. How to edit a Post Family directly from an existing Railing Family?
    By craighowie in forum Revit Architecture - Families
    Last Post: 2009-12-04, 06:07 AM
  3. How to edit a post family directly from an existing railing family?
    Last Post: 2009-11-29, 01:36 PM
  4. Railing Profile Family Will not Show Up
    By Kevin Janik in forum Revit Architecture - General
    Last Post: 2007-12-12, 11:10 PM
