Is there any indications from autodesk if they will be supporting a multi-processor system in the future? My company is planning on purchasing a computer specifically for rendering stills and video in revit. Ive been given a budget of between 4 and 7 thousand doallars, wich I know should be able to purchase the fastest stuff out there. Should I go ahead and order somthing with dual Xeon's in the hope that revit will support it eventually? This is what im considering.
PROCESSOR Quad Core Intel® Xeon® Processor X5450 (3.00GHz,2X6M L2,1333)
2ND PROCESSOR Quad Core Intel® Xeon® Processor X5450 (3.00GHz,2X6M L2,1333)
VIDEO CARD 512MB PCIe x16 nVidia Quadro FX1700, Dual Monitor DVI Capable edit
MEMORY 4GB, DDR2 SDRAM FBD Memory, 667MHz, ECC (4 DIMMS) edit
OPTICAL DRIVE 16X DVD+/-RW w/ Cyberlink PowerDVD™ and Roxio Creator™ Dell Ed
RAID CONFIGURATION C1 All SATA drives, Non-RAID, 1 drive total configuration
HARD DRIVE 160GB SATA, 10K RPM Hard Drive with 16MB DataBurst Cache™
MONITOR Dell 24 inch E248FP Widescreen Flat Panel, Analog edit
