Thread: Reverse polyline and maintain Object Data
    2005-12
    90
    Default Reverse polyline and maintain Object Data
    I recently downloaded a lisp routine called rev. This lisp reverses the direction of lines and polylines. I was using the routine to correct the direction of one way streets in a centerline file. After checking the polylines afterwards, the Object Data with the streetnames was missing. Using an older drawing I tried using 'Reverse Link Direction' with a network topology and was not successful. The command would belong under Network Topology Editting, Edit Object Data, or Drawing Cleanup.
    TC
    TN/KY Area
    1,640
    Default Re: Reverse polyline and maintain Object Data
    Here's a tool that claims to work
    http://www.4d-technologies.com/geoto...tool_set_1.htm
    but yes this is a good wish.
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. Reverse Polyline lisp
    By Richard McDonald in forum AutoCAD General
    Last Post: 2011-06-24, 01:30 PM
  3. Extract Elevation Object Data and Assign to Polyline Contour
    By clarkl in forum AutoCAD Map 3D - General
    Last Post: 2009-04-01, 04:53 PM
  4. Reverse direction of curved polyline?
    By anderson.scottglen in forum AutoLISP
    Last Post: 2007-05-08, 12:22 PM
