Thread: Can't Copy and paste
    2006-10
    48
    Default Can't Copy and paste
    I have several drawings that have been cleaned up in 2007 and saved back to 2000 format. However, we have noticed that you cannot copy or paste anything that is within the drawing. Example: Tried to copy/w/basepoint a line and paste anywhere. _pasteclip appears on the command line, but nothing else. Nor can you create blocks/wblocks. We see this a lot with drawings converted from 2007. Generally our fix is to insert the drawing into a new drawing as a bock. Then everything works fine. However, several of these drawings have automation tied into them, and if you copy the Automation parts, then they do not work anymore.and you have to start over..which takes hours. I can paste things in from other drawings, just cannot move anything to the clipboard from these particular drawings. Any ideas?
    2003-12
    Pittsburgh, PA
    355
    Default Re: Can't Copy and paste
    2006-10
    48
    That fixed it. Thank you very much.
  1. Copy and Paste
    By rlh in forum AutoCAD General
    Last Post: 2009-06-01, 11:43 AM
  2. Copy no paste
    By cjshaw in forum AutoCAD General
    Last Post: 2009-03-31, 08:51 PM
  3. Cannot Copy & Paste
    By jeff.garr in forum AutoCAD General
    Last Post: 2006-07-23, 11:06 AM
  4. Copy and Paste
    By Robert.Hall in forum AutoCAD General
    Last Post: 2004-11-02, 04:50 PM
