Results 1 to 1 of 1
Thread: [FMDesktop] Wish for the ability to add multiple spaces to zones from the graphical interface
    2001-12
    St. Louis
    5,408
    Post [FMDesktop] Wish for the ability to add multiple spaces to zones from the graphical interface
    Product Component: Facility Manager
    Description:
    Need to be able to add multiple spaces at a time from the graphical interface in the Zone dialog box.
    How Used: Currently (FMD7.1) you can select to add multiple spaces to a 'Zone' in the Spaces tab of the Zone dialog using the text interface. But, when utilizing the 'Select from Drawing' interface (where you pick spaces from the desired DWF file), you can only select one space at a time, then hit ok, rinse and repeat.
    Feature Affinity: Um... data management? Selection? Interface?
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Assigning Spaces to Zones via Input
    By Mac001 in forum Revit MEP - General
    Last Post: 2012-02-15, 05:49 PM
  2. Using Spaces & Zones
    By buzz in forum AMEP General
    Last Post: 2010-10-14, 03:57 PM
  3. Do you guys set up spaces and zones?
    By oshalygin in forum Revit MEP - General
    Last Post: 2010-10-11, 02:53 PM
  4. Spaces/ Zones/ Space Evaluations
    By HeribertoOlivo in forum ACA General
    Last Post: 2008-09-09, 05:53 PM
