Thread: Office 2007 Spellcheck Revit 2008
    2006-08
    14
    Default Office 2007 Spellcheck Revit 2008
    Spellcheck does not work with Revit 2008 once you upgrade to Office 2007. Is there a patch (new build) for this? Also is the Revit Structure dictionary comparable to Microsoft Office dictionary since this option is available currently?
    I could stop if I wanted to Misteracad's Avatar
    Philadelphia, PA
    349
    Default Re: Office 2007 Spellcheck Revit 2008
    I had the same problem when I installed Office 2007, but the latest build of Revit Structure (at the time I believe it was Aug '07) fixed it. Are you running the latest build? The available dictionary options should update as well.
    Timothy S. Kramer
    AEC BIM Specialist
    "Just because you can doesn't mean you should!!!"
    "You don't know what you don't know!"
    What am I doing HERE??? I should be working on my Nash!
  1. Revit API and Open XML SDK 2.0 and Office 2007
    By pfaudler in forum Revit - API
    Last Post: 2010-05-24, 12:16 PM
  2. Office 2007
    By dbhaskin in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-12-05, 08:55 PM
  3. Zoom to word while using spellcheck
    By .chad in forum ACA Wish List
    Last Post: 2007-06-07, 02:45 PM
  4. AutoCAD 2007 LT - import DWG into Microsoft Office Word 2003
    By sstadnyk2002 in forum AutoCAD LT - General
    Last Post: 2007-01-30, 09:40 AM
