If you want to hatch an area whose boundary is not quite closed, you can set the HPGAPTOL system variable to bridge gaps and treat the boundary as closed. HPGAPTOL applies only to gaps between lines and arcs that, if extended, would meet.
Great. This will be very useful. Thanx for the tip.
Cheers
You can change this variable directly in the Hatch dialog box
and if you need it closed.............
I remember seeing a lisp routine somewhere that will draw a circle
around each spot that isn't closed. Anyone have something?
I've got a couple stashed away somewhere if you really want me to find them.
one started out as a routine called "Chain".
You touch a line or PL and the routine goes around the "object making sure that all the lines end where the next begins. It changes the color of the line as it goes forward successfully and changes it back when complete. If it finds a gap it ends right there, leaving the line color wrong.
Look for gap.lsp at http://www.spaug.org/LISP_Index99.Html
Martin
