Is is possible to create a cabel tray in revit mep like we have in autocad mep.
thanks
satish
thanks
satish
I'd make a line-based family.
Generic model, perhaps -- you cannot make new categories, just sub-categories.
Check out this thread. Someone may have already gone to the trouble for you although I'm not sure it was fully resolved.
http://forums.augi.com/showthread.ph...ght=cable+tray
I have created a cable tray with a clearence above the tray for collision detection. I used a generic line-based family and changed the catagory to electrical equipment. The thing is you have to insert the straight segment, then the elbow then the tee. Not like ductwork where you can click...click...click and draw all the needed fiitings by setting the defaults.
I created a cable tray profile and used sweeps to create the elbows and cable tray.
I hope this helps,
Glen Walson
Application Specialist
Ideate Inc.
In my search for a workable cable tray to use in an older Revit project I found this:
http://revitmepcad.blogspot.com/2010...able-tray.html
Conduit and cable tray is available in Revit MEP 2011.
Autodesk Revit MEP 2011 - Conduit Layouts
http://www.youtube.com/watch?v=LUHpX0YWq2w
Autodesk Revit MEP 2011 - Cable Tray Layouts
http://www.youtube.com/watch?v=F2zcs884ceY
