buzz
I am trying to make the Rise/Drop for all my duct fittings show up with a 1.0 LTS and a Lineweight of 0.010". This has worked with other objects, but doesn't seem to work for the rise/drop for the fittings.
I thought that maybe I was changing the properties of the wrong item, but if I turn off the "Rise Drop" Display Component, the correct lines turn off, so I am pretty sure I am changing the right component.
You can see in the screenshot that changing both the LTS (to 1.0 from 0.5) and the Lineweight (from BYLAYER to 0.010") does not modify the lines - they still show up with a LTS of 0.5 and a lineweight of 0.020" (which is BYLAYER).
-Buzz
