Thread: Better railing functionality
    Wish List Administration
    2007-08
    603
    Default Better railing functionality
    Summary: A railing tool that better deals with real life conditions of required railing extensions and returns (including multi-flight stairs & landing transitions), and baluster locations. As well as better handling of common commercial/institutional railing types like monolithic glass.
    Description: A railing tool that better deals with real life conditions of required railing extensions and returns (including multi-flight stairs & landing transitions), and baluster locations. As well as better handling of common commercial/institutional railing types like monolithic glass.
    How Used: I have worked on two projects that require monolithic glass railings. These types of rails require custom placed joints between the panels. I need to be able to place "balusters" or joints at regular intervals, I also need to tweak the location based on stair runs or length. The same is true for common metal picket rails with regards to correct baluster placement, and dealing with how all rails return to each other at ends & on multi-flight stairs.
    Feature Affinity: Stairs, Ramps, and Railings
    Submitted By: Robert Manna on September 24, 2007
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Default Re: Better railing functionality
    It is clear that the railing tool needs a ton of work. On any stair that is just a tiny bit unusual the railing tool produces wacky results. There really isn't a way to tweak railings to achieve what you want.
    I could stop if I wanted to rmejia's Avatar
    2006-10
    Puerto Rico
    432
    The actual railing tool does present limitations, especially where railing meet and change level. Railings are probably one of the more complicated features to design. I hope this tool someday gets updated to be able to achieve "real" railings as they are built with ought the awkward connections it currently creates.
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    637
    Thumbs down Re: Better railing functionality
    Railing is really difficult to make automatically. That's why we have some limitations... On the other hand, the limitations are too many.
    Some times good generic modeling tools could make the difference
    Some other times, breaking the sketch lines could help a little.
    Generally, I don't use railings when making stairs, they are always wrong.
    2011-08
    4,584
    Exclamation Re: Better railing functionality
    Product and Feature: Revit Architecture - Stairs
    Submitted By: robert.manna on 09/24/2007
    2011-08
    4,584
  1. Add more functionality to the Options Bar
    Last Post: 2014-10-28, 01:10 PM
  2. Dot Net vs VBA ... Speed and Functionality
    By e_casagrande394681 in forum Dot Net API
    Last Post: 2014-03-06, 02:05 AM
  3. 2013: Railing issue making a Mesh Panel Railing need help
    By billy007nh in forum Revit Architecture - General
    Last Post: 2012-07-02, 04:28 PM
  4. MAP Functionality
    By mjfarrell in forum Civil 3D Wish List
    Last Post: 2011-11-23, 06:57 AM
  5. CUI's and command functionality?
    By mcoffman in forum AutoCAD CUI Menus
    Last Post: 2005-09-13, 05:39 PM
