Results 1 to 10 of 14
Thread: SolidWorks vs. AutoCAD?
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,287
    Cool SolidWorks vs. AutoCAD?
    Is there anyone out there in AUGI-Land who's used (or uses) SolidWorks?
    If so, can you tell me how does it compare to AutoCAD?
    Similarities & Differences?
    Menus? Tools? Macros? Programming (Script/Autolisp)?
    Layouts (Paperspace etc.)? Commands?
    From what I understand it's a 3D modeling program like "Inventor" (which I don't know much about), I'd like to know as much as I can find out.
    Thanks.
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    0,0,0 The Origin
    8,026
    Default Re: SolidWorks vs. AutoCAD?
    Solidworks doesn't compare to Acad - as you said, it compares to Inventor and to SolidEdge, Pro/E, SolidDesigner, etc..
    In all of them you create a model then produce drawings from it.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    AutoCad is by far, the leader for 2d drawings. The price is right and the
    software is very sophisticated for its purpose.
    2005-06
    2,287
    Quote Originally Posted by jaberwok View Post
    Thanks, what about the other stuff?
    How do you interface with it (pull down menus, tool bars, command line)?
    Can you customize it (like pgp, lisp etc.)?
    Ted
    0,0,0 The Origin
    8,026
    Toolbars mainly. Like all newer Windows programmes you can choose which toolbars to display and drag buttons around and between them to customise them.
    John B
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    Which can be a rather painful adjustment when you "cut" your teeth on AutoCAD. I still sometimes try to use Command: line functions in other programs.
    I loved the NCS so much, I joined the committee!
    "Truth suffers from too much analysis"
    I remember AutoCAD R10
    When will Autodesk port AutoCAD to Linux?
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    Except Revit....of course!
    0,0,0 The Origin
    8,026
    Quote Originally Posted by whittendesigns View Post
    Really ?
    John B
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    I have never had a problem with customizing what you want displayed as for toolbars and buttons in Revit.
    As for solidworks it is a 3D modeling program which can produce 2D drawings from the 3D model. I am sure that you can run vba or some other api, but I am not sure about the lisp/macro abilities since I have not used it enough to comment on that. There really is no such thing as paperspace, but I think a seperate drawing for the 2D paper. (It has been awhile)
    2005-06
    2,287
    Quote Originally Posted by marklabell View Post
    Thanks for the information.
    Ted
  1. How to convert a Solid Model from SolidWorks to AutoCAD
    By james.schultz in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-06-15, 12:01 PM
  2. Career advice - Autocad vs Solidworks
    By wayneh789 in forum Training
    Last Post: 2010-07-11, 05:17 PM
  3. Solidworks?
    By christian.lacroix in forum Revit Structure - General
    Last Post: 2009-07-13, 12:40 AM
  4. Import Solidworks model into AutoCAD
    By Grumpy in forum Software
    Last Post: 2007-05-09, 06:30 PM
  5. Upgraded VBA in AutoCAD/SolidWorks 2008 by WorldCAD Access
    By Mike.Perry in forum VBA/COM Interop
    Last Post: 2005-09-21, 03:21 AM
