Thread: Louver - Parametric
    Member dysart's Avatar
    2001-01
    27
    Default Louver - Parametric
    I created a parametric louver family with help / instructions from one of Mr. Spot's posts.
    It seemed to work well, until I noticed that the louver blades were showing up in plan views incorrectly. The family looks good in elevation, section and normal plan views; however,
    if one raises the louver sill to above the view's cut plane, one sees an isolated louver blade.
    The blades are a nested family within the louver family, and I suspect the problem lies within the nested louver blade family. I tried to modify the blade family without success.
    Thoughts are appreciated,
    Greg
    2002-02
    St. Louis, MO
    4,695
    Default Re: Louver - Parametric
    You just need to set things so they only show wne cut in plan. Not when they are viewed in plan... I think this is what you are after...
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    2001-01
    27
    Thanks Aaron,
    That certainly makes all the blades disappear in plan views, but it seems odd that the blade geometry, when left visible in plan views, is seen outside of it's "real" location.
    Greg
    2004-10
    114
    just a guess ...
    Check the louver family to ensure there's no geometry that would still overlap the plan's cut plane even if the louver geometry didn't. It's common to place vertical invisible lines in families to ensure they'll display in plan ... even though they may exist above the cut plane.
  1. Parametric Louver Family
    By scott.farrar4691938 in forum Revit MEP - Families
    Last Post: 2012-10-22, 12:06 PM
  2. 2012: Parametric Array Help: Louver
    By SCOWBOY74 in forum Revit Architecture - Families
    Last Post: 2012-02-29, 07:21 PM
  3. Parametric Shade Louver
    By annl in forum Revit Architecture - Families
    Last Post: 2007-12-10, 12:28 AM
  4. I need a wall louver!
    By blumarble in forum Revit Architecture - Families
    Last Post: 2006-08-06, 11:32 PM
  5. Parametric History/Action list or Parametric Schematic view
    By Richard McCarthy in forum Revit Architecture - Wish List
    Last Post: 2004-09-21, 01:42 AM
