Thread: Copying elements changes associated level
    2006-06
    Southern California
    35
    Default Copying elements changes associated level
    Whenever I copy an element, like a column for instance, the associated base level changes. Both levels are at the same elevation but named differently and are for separate buildings. There are seven buildings with differently named levels at the foundation all at the same elevation. All new entities default to one of these levels even when using copy and the original entity was associated with a different level.
    Matthew
    2007-02
    Hendo, Nevada
    99
    Default Re: Copying elements changes associated level
    What level is the view you are copying into set to? If you have seven different levels all at the same elevation then the plan views you created at that elevation might all have the same levels set as the work plan. You might be able to fix this by setting the work plane to the level for the building you are currently working on and then pasting.
  1. Copying Dimensions to another Level
    By Galadriel in forum Revit Structure - General
    Last Post: 2019-05-03, 04:01 AM
  2. Retain workset association when copying elements to another location.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2015-12-14, 03:04 PM
  3. 2013: Linked models - Copying elements
    By stephanschneller in forum Revit Architecture - General
    Last Post: 2013-03-26, 08:48 PM
  4. Copying sloping pipes from one level to other
    By Shweta in forum Revit MEP - General
    Last Post: 2010-08-18, 04:08 AM
  5. merging / copying elements
    By bnix in forum Revit Architecture - General
    Last Post: 2005-01-04, 08:13 PM
