Results 1 to 6 of 6
Thread: keyboard shortcut
    2005-07
    98
    Default keyboard shortcut
    hey guys i created a keyboard shortcut for thr close command as ctrl+w
    however i would liek to take this one step up by firts getting it to zoom extenst and then closing drawing
    so if i hit ctrl+w , it will first zoom extents then close drawing is there a way to do this
    i tried in CUI adding two commands together under keyborad shortcuts and editing the macro under teh command drop down , but I thnk i am missing a varriable to make it work right
    so i would like to know how do i combine two commands in one keyboard shortcut
    like; CTRL+W = zoom extents then closes drawing
    (that is what i want it do, currently Ctrl+W just closes drawing)
    thank you
    Earth
    9,805
    Default Re: keyboard shortcut
    ._zoom;_e;._close;
    R.K. McSwain | CAD Panacea |
    2005-07
    98
    i copied what you wrote into my cui macro for ctrl+w it still doesn't work
    2005-07
    98
    sorry i got it working
    i was editing close command under civil and my shortcut was be controlled by ACAD
    so i changed them both and it is working
    thank you
    100 Club CADTigress's Avatar
    2003-09
    St. Louis , MO
    145
    ._zoom;_e;._close;
    that is Awesome! What if you want to put it back to the default? When you create a shortcut key will it permanently change the key?
    I normally have 20 or more drwgs open and when I am ready to go I type in CLOSEALL
    Then just hit the Y button.................closes all and saves,...........I Love that command!
    2005-07
    98
    for me closeall is CTRL+SHIFT+W, but now i have added zoom extents to that as well
    i bet there is way to also a way to put default answer as yes
  1. 2012: Keyboard Shortcut for Arc
    By SonicDeathMonkey in forum Revit MEP - General
    Last Post: 2012-02-15, 05:18 PM
  2. Keyboard Shortcut 2010
    By j_menacker in forum NavisWorks - General
    Last Post: 2010-03-19, 03:37 PM
  3. Mleader keyboard shortcut?
    By gfreddog in forum AutoCAD General
    Last Post: 2008-08-28, 04:49 PM
  4. Keyboard Shortcut Keys
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-02-22, 01:34 PM
  5. keyboard shortcut
    By sfaust in forum Revit Architecture - General
    Last Post: 2004-08-12, 01:51 AM
