Thread: I am having a problem with TEXTMASK and annotative text
    2003-11
    427
    Default I am having a problem with TEXTMASK and annotative text
    When I try to use TEXTMASK with annotative text, the text object increases in size. Does anybody know of a fix for this?
    Update:
    I have found that I don't need to use TEXTMASK for mtext because I can turn on background masking but I still have a problem when i use single line text. I guess I could always just use mtext.
    2004-06
    Lacombe, Louisiana
    137
    Default Re: I am having a problem with TEXTMASK and annotative text
    i created some dtext using annotative property. then used the express tool masktex and the text disappeared but masked the lines that ran through the text. if i create dtext w/o annotative property and mask it, it wipes out the lines like it is supposed to. don't have a clue as to why?
    I also tried using background masking with annotative mtext with multiple annotative scales. The result was the mask area shows up for all scales, not just the current one. After some more experimention with annotative text, it appears that it is does not play well with masking of any sort.
    after a little more playing with it, my statement above is not accurate. this is going to require some more experimentaion.
    Robert
    2006-06
    Phoenix, AZ
    2
    I modified the textmask lisp to bring the existing text to the front instead of recreating the text to solve this problem. Did it quickly and sloppily so there is no attempt at elegance just functionality.
    ; ----------------- MASK USING WIPEOUT FUNCTION ------------------
    ;   This function draws a wipeout under text TXT using the
    ;   offset value OSET
    (defun acet-textmask-make-wipeout (ENT OSET / TXT TXTLAY TBX WIPOUT TXTYP TXTSTR)
      (setq TXT    (entget ENT (list "*"))               ; Get the text's edata
            TXTLAY (cdr (assoc 8 TXT))                   ; Get the layer of the text
            TXTYP  (cdr (assoc 0 TXT))                   ; Text or Mtext
            TXTSTR (cdr (assoc 1 TXT))
      (if (/= TXTSTR "")
        (progn
          (if (= TXTYP "TEXT")
            (acet-ucs-cmd (list "_object" ENT))              ; set UCS to object
            (acet-ucs-to-object ENT)
          (setq TBX (acet-geom-textbox TXT OSET))              ; Get the points around the text
          (if TBX
            (progn
              (command "_.pline")                        ; Create bounding pline box
               (while TBX
                (command (car TBX))
                (setq TBX (cdr TBX))
              (command "_c")
              (command "_.wipeout" "_Polyline" (entlast) "_yes")  ; create wipeout entity
              (setq WIPOUT (entlast))
              (command "_.change" WIPOUT "" "_Prop" "_Layer" TXTLAY "_cOLOR" "255" "") ; and set its layer
              (acet-ucs-cmd (list "_previous"))              ; reset the ucs
    ;          (entmake TXT)                              ; recreate text
              (setq TXT ENT)                       ; such that it's on top
                      (command "_.draworder" TXT "" "Front")
              (acet-xdata-set (list WIPOUT "ACET-TEXTMASK"
                              (list
                                (list "TextObject" (cdr (assoc 5 (entget TXT))) 1005)
                                (list "Offset" OSET 1040)
              (acet-xdata-set (list TXT "ACET-TEXTMASK"
                              (list
                                (list "MaskObject" (cdr (assoc 5 (entget WIPOUT))) 1005)
                                (list "MaskType" "WIPEOUT" 1000)
              (command "_.move" TXT "" "0,0" "0,0")
              (acet-group-make-anon (list WIPOUT TXT) "In use by TEXTMASK") ; make the text and wipeout a group
    ;          (entdel ENT)                               ; delete original text
          ); if TBX
        ); progn then
      ); if not ""
  1. 2011: annotative text and annotative block failure
    By kuruczregina in forum ACA General
    Last Post: 2012-03-25, 06:56 PM
  2. Mtext Background vs. ExpressTools Textmask Problem
    By john.miller in forum AutoCAD General
    Last Post: 2008-10-01, 04:05 PM
  3. Replies: 4
    Last Post: 2007-11-26, 09:22 PM
  4. Annotative text and text count
    By Homerloew in forum AutoCAD Annotation
    Last Post: 2007-10-25, 02:31 AM
  5. Why is Textmask no longer associated with my Text
    By mcatalano in forum AutoCAD General
    Last Post: 2006-08-09, 03:34 AM
