Thread: Base Point
    2007-09
    15
    Default Base Point
    I did a X-Y parameter with a lookup to scale our baseballs to the correct pipe OD, but the block grip in the center of the baseball is no longer available with the X-Y parameter grip both at 0,0.
    Is there a way to hide the X-Y grip so I can continue using the block grip?
    Or is there a better way to scale all of these?
    2007-09
    15
    Default Re: Base Point
    scratch that... found it under properties for the x-y parameter. number of grips = 0
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by mbreeden View Post
    it can also be found w/ the right-click menu after selecting
    S&D DB Sharing Forum
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    Quote Originally Posted by Chris.N View Post
    Umm... I see no on my right click menu to select.
  1. 2014: Point de base du projet
    By T.SANSON in forum Revit Architecture - General
    Last Post: 2015-02-23, 10:26 AM
  2. 2014: Rotate a XYZ Point Around Base Point
    By sam.zielke437771 in forum Revit - API
    Last Post: 2014-08-11, 03:42 AM
  3. Survey Point and Project Base Point Visible in new views
    By amjones in forum Revit Architecture - General
    Last Post: 2013-03-12, 10:23 PM
  4. Replies: 3
    Last Post: 2012-05-07, 04:26 PM
  5. Replies: 0
    Last Post: 2011-12-03, 09:13 AM
